Fax Testing
Discussion in '3CX Phone System - General' started by bsockel, Oct 13, 2015.
  1. bsockel
    Oct 9, 2015
    Hey Guys,
    I am attempting to do some fax testing with the 3cx and Relayfax from Alt-N. I am able to get the 3cx PBX setup and working. I am able to use the soft phone to sign into an extension to other extensions and make calls through our Beronet gateway.
    I am running into an issue when i define a Fax Extension in the 3CX system. I attempt to call a fax extension from a 3cx softphone but nothing happens on the first out going call. The phone just sits there for a minute and then says it is On Hook. on the second call it does ring, but my fax server never picks up the extension. I have a second fax extension that when you call it nothing happens, just kind of sits there with dead air then disconnects.
    I have 3 extension that i am working with on my 3cx:
    Extension 1001 - Softphone
    Extension 8000 - Fax Line 1
    Extension 8001 - Fax Line 2
    Extension 1001 works fine, can dial out no issues.
    Extension 8000 Rings when i dial it, but fax software never picks up, so just rings for ever.
    Extension 8001 Seems to do nothing when i call it, just dead air.
    I am using an unlicensed version of the 3CX PVX.
    Is there something that i am missing?
    Here is part of the server activity log:
    Code:
    13-Oct-2015 15:44:07.169   Leg L:36.2[Fax] is terminated: Cause: 487 Request Terminated/INVITE from 10.10.50.109:50849
    13-Oct-2015 15:44:07.169   [CM503003]: Call(C:36): Call to <sip:8800@10.10.50.109:50849> has failed; Cause: 487 Request Terminated/INVITE from 10.10.50.109:50849
    13-Oct-2015 15:44:07.070   [CM503008]: Call(C:36): Call is terminated
    13-Oct-2015 15:44:07.068   Leg L:36.1[Extn] is terminated: Cause: CANCEL from 10.10.50.233:62303
    13-Oct-2015 15:43:57.154   [CM503025]: Call(C:36): Calling T:Fax:8800@[Dev:sip:8800@10.10.50.109:50849;rinstance=0-f578adb9e32b4e76a50427ae55adf48f;ob] for L:36.1[Extn]
    13-Oct-2015 15:43:57.106   [CM503027]: Call(C:36): From: Extn:1001 ("1001" <sip:1001@10.10.50.108:5060>)  to  T:Fax:8800@[Dev:sip:8800@10.10.50.109:50849;rinstance=0-f578adb9e32b4e76a50427ae55adf48f;ob]
    13-Oct-2015 15:43:57.106   [CM503004]: Call(C:36): Route 1: from L:36.1[Extn] to T:Fax:8800@[Dev:sip:8800@10.10.50.109:50849;rinstance=0-f578adb9e32b4e76a50427ae55adf48f;ob]
    13-Oct-2015 15:43:57.105   [CM503001]: Call(C:36): Incoming call from Extn:1001 to <sip:8800@10.10.50.108:5060>
    13-Oct-2015 15:43:57.104   NAT/ALG check:L:36.1[Extn] REQUEST 'INVITE' - basic check passed. No information for extended checks
    13-Oct-2015 15:43:21.107   [CM504009]: Fax Service: Fax.8800 changed contact to sip:8800@10.10.50.109:50849;rinstance=0-f578adb9e32b4e76a50427ae55adf48f;ob
    13-Oct-2015 15:42:25.044   [CM504009]: Fax Service: Fax.8800 changed contact to sip:8800@10.10.50.108:5063
    13-Oct-2015 15:42:08.585   Leg L:35.1[Extn] is terminated: Cause: BYE from PBX
    13-Oct-2015 15:42:08.535   Leg L:35.2[Fax] is terminated: Cause: 408 Request Timeout/INVITE from local
    13-Oct-2015 15:42:08.531   [CM503020]: Call(C:35): Normal call termination. Call originator: Extn:1001. Reason: No answer
    13-Oct-2015 15:42:08.530   L:35.1[Extn] failed to reach Fax:8801, reason No Answer
    13-Oct-2015 15:42:08.530   Call to T:Fax:8801@[Dev:sip:8801@10.10.50.108:5064] from L:35.1[Extn] failed, cause: Cause: 408 Request Timeout/INVITE from local
    13-Oct-2015 15:42:08.530   [CM503003]: Call(C:35): Call to <sip:8801@10.10.50.108:5064> has failed; Cause: 408 Request Timeout/INVITE from local
    13-Oct-2015 15:42:02.290   Currently active calls - 1: [35]
    13-Oct-2015 15:41:44.767   Leg L:34.2[Fax] is terminated: Cause: 408 Request Timeout/INVITE from local
    13-Oct-2015 15:41:44.767   [CM503003]: Call(C:34): Call to <sip:8801@10.10.50.108:5064> has failed; Cause: 408 Request Timeout/INVITE from local
    13-Oct-2015 15:41:36.430   [CM503025]: Call(C:35): Calling T:Fax:8801@[Dev:sip:8801@10.10.50.108:5064] for L:35.1[Extn]
    13-Oct-2015 15:41:36.382   [CM503027]: Call(C:35): From: Extn:1001 ("1001" <sip:1001@10.10.50.108:5060>)  to  T:Fax:8801@[Dev:sip:8801@10.10.50.108:5064]
    13-Oct-2015 15:41:36.382   [CM503004]: Call(C:35): Route 1: from L:35.1[Extn] to T:Fax:8801@[Dev:sip:8801@10.10.50.108:5064]
    13-Oct-2015 15:41:36.380   [CM503001]: Call(C:35): Incoming call from Extn:1001 to <sip:8801@10.10.50.108:5060>
    13-Oct-2015 15:41:36.380   NAT/ALG check:L:35.1[Extn] REQUEST 'INVITE' - basic check passed. No information for extended checks
    13-Oct-2015 15:41:33.130   [CM503008]: Call(C:34): Call is terminated
    13-Oct-2015 15:41:33.130   Leg L:34.1[Extn] is terminated: Cause: CANCEL from 10.10.50.233:62303
    13-Oct-2015 15:41:32.153   Currently active calls - 1: [34]
    13-Oct-2015 15:41:12.719   [CM503025]: Call(C:34): Calling T:Fax:8801@[Dev:sip:8801@10.10.50.108:5064] for L:34.1[Extn]
    13-Oct-2015 15:41:12.671   [CM503027]: Call(C:34): From: Extn:1001 ("1001" <sip:1001@10.10.50.108:5060>)  to  T:Fax:8801@[Dev:sip:8801@10.10.50.108:5064]
    13-Oct-2015 15:41:12.671   [CM503004]: Call(C:34): Route 1: from L:34.1[Extn] to T:Fax:8801@[Dev:sip:8801@10.10.50.108:5064]
    13-Oct-2015 15:41:12.669   [CM503001]: Call(C:34): Incoming call from Extn:1001 to <sip:8801@10.10.50.108:5060>
    13-Oct-2015 15:41:12.669   NAT/ALG check:L:34.1[Extn] REQUEST 'INVITE' - basic check passed. No information for extended checks
    13-Oct-2015 15:40:39.814   [CM504008]: Fax Service: Fax.8801 registered as sip:8801@10.10.50.108 with contact sip:8801@10.10.50.108:5064
    13-Oct-2015 15:40:39.527   [CM504010]: Fax Service: Fax.8801 unregistered contact sip:8801:5064
    Thanks,
  2. pj3cx
    pj3cx Active Member
    Aug 1, 2013
    645
    Hi there,
    Please elaborate how is used the beronet gateway, do you want to receive faxes on the gateway then on analog fax machine or do you receive on the system fax extension for mail sending?
