fax to email troubleshooting
Discussion in '3CX Phone System - General' started by jonnybluehat, Jul 28, 2011.
  1. jonnybluehat
    Feb 15, 2011
    8
    just wondering if there's a log for fat to email
    system is accepting faxes but when it goes to email i get nothing
    the email acct is good i can sign in and send and receive all day
    its exch 2010 if it helps
  2. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    I have a similar problem trying to send fax to a different domain.
    I'm using an Exchange 2003 (running on a different machine in the same LAN) and I have my domain - my_example_domain.com. The 3CX server has a system e-mail account: 3cx@my_example_domain.com.
    It is OK to send faxes to: any_name@my_example_domain.com but not to: any_name@gmail.com, etc.
    But I'm able to send voice-mails to any e-mail.
    Check this in your case.
    Regards.
