Fax to mail configuration
Discussion in '3CX Phone System - General' started by Kico55, Jun 19, 2017.
  1. Kico55
    Jun 8, 2015
    Hello!
    I have installed 3CX Phone System and want to configure Fax to mail
    I want that, if a fax comes on my SIP number, 3CX phone system send this fax on my mail in pdf format.
    But i dont want to use software ore fax machine.
    Is this possible from 3CX phone system? If yes, how can i configure it?
    Thank you
  2. teldata1
    Aug 24, 2015
    63
    Yes, 3CX can do this. Go to Incoming Rules->Add DID Rule. Choose the DID you want faxes sent to, then under "Destination for calls during office hours" click the drop down box and choose "Send FAX to" and underneath, choose the extension (email) you want the fax emailed to.
  3. Kico55
    Jun 8, 2015
    Thank you for reply. Extansion should be an normal Extansion with mail inserted to it or an FAX Extansion? Any configuration on Fax server?
    Thank you
  4. teldata1
    Aug 24, 2015
    63
    Sorry I made a mistake, you want to send incoming calls to the DID to the fax server (ext 888), you can modify the email address of the fax server in Settings->FAX Server
    JasonNadeau likes this.
  5. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    5,514
    361
    @Kico55
    Please note that you can send the Fax to any extension you want that has a configured email address.
    No additional configuration to the FAX required.
    Just create an inbound rule for the DID that you want to use for FAX and point it to the extension you want.
