FAX VIEWER
Discussion in '3CX Phone System - General' started by dimitripapa, Feb 19, 2013.
  1. dimitripapa
    Feb 19, 2013
    IS IT POSSIBLE TO VIEW & DELETE THE INCOMING FAXES FROMTHE FAX SERVER USING THE BROSWER?
  2. AndreasP_3CX
    AndreasP_3CX New Member
    3CX Support
    Feb 15, 2013
    196
    Unfortunately as far as i know it is not possible
