FAX + Voice using one FXO
Discussion in '3CX Phone System - General' started by fychan, Jun 14, 2010.
  1. fychan
    Sep 4, 2009
    9
    Hi there,
    I'm using the Patton Gateway 4114.
    Please advice if 3CX is able to differentiate its a Fax or voice call?
    Is it possible to divert the call to a FAX ext if its a fax and forward it to an autoattendent if its a voice call?
    Where and how its configured?
    regards
    Fei Yu
  2. carolinainnovative
    May 4, 2009
    369
    6
    I'm gonna say no on that one... although that would be a great feature.
    From what i've seen, you could have it where they call in and press a digit to send a fax. I don't know if it still works, but this guy had luck with it...
    http://www.3cx.com/forums/fax-from-digital-receptionist-11463.html
  3. stuart.rendall
    May 26, 2010
    25
    I would really like to see this feature as well
