Fax with Linksys 3102
Discussion in '3CX Phone System - General' started by muaddib32, Feb 19, 2011.
  1. muaddib32
    Oct 16, 2010
    68
    I have set this up as described on the 3CX website (http: //www.3cx.com/sip-phones/linksys-spa-3102-fax/ no longer available. New link:http://www.3cx.com/sip-phones/). I can make and receive phonecalls. However, outbound faxes do not complete. I get an error report that the number is busy.
    It is not the provider. They have supported fax through a Linksys SPA9000 for the past four years.
    Any idea what the problem could be?
    11,123
    330
    Fax problems have come up many, many times in the past. Have you done a search through the forums? Some people have been able to solve some issues. Are you are using a fax machine on the FXS port of the 3102, passing through 3CX and out on a VoIP provider, or using a fax machine connected to the FXS port, passing through 3CX and then out on a trunk using the FXO port?
  3. muaddib32
    Oct 16, 2010
    68
    Okay, I established that it was most definitely NOT a problem with either the provider or the Linksys 3102. Faxes worked fine if I turned off 3CX and connected the 3102 directly to the provider.
    So how does one get 3CX to work with an analog fax? I followed the instructions in (http: //www.3cx.com/sip-phones/linksys-spa-3102-fax/ NO LONGER AVAILABLE. NEW LINK: http://www.3cx.com/sip-phones/) and that does not work. The instructions there point to using a normal extension to send faxes. This does not work. The handshake between the sending and receiving faxes is not completed. From my reading elsewhere this will not work as 3CX does not pass T38 on normal voice extensions. Which conforms with my experience with the PAP2T which does not support T38 and displayed the same symptoms.
    So, the 3102 must be connected to a fax extension. I did that and once I realised I didn't have an outbound rule for the fax extension was able to send faxes.
    Now..how do I receive faxes? Again according to (the above mentioned guide)I set the 3102 to the extension 888 and disabled the fax server. Didn't work. The calls were not being handled by the system at all. So I turned the fax server back on, configured an additional fax extension (889), set it to forward faxes to fax device 889 and it worked.
    So here's my instructions for getting a Linksys SPA3102 to work:
    1) ignore the instructions at of the guide
    2) upgrade the firmware to 5.1.10
    3) leave all the settings at default (T38 is enabled by default)
    4) set up a fax extension on the 3CX phone system
    5) configure Line 1 on the 3102 to connect to your new fax extension
    6) make an outbound rule for your fax extension that allows the leading digit to be left off (remember to remove the strip digit from your outbound rule)
    7) set an inbound rule for the inbound number/DID to "send fax to FAX device xxx'
