Solved Fax with Patton Gateway
Discussion in '3CX Phone System - General' started by ntnetzeband, Mar 22, 2018.
  1. ntnetzeband
    Jul 30, 2016
    65
    5
    Has anyone implemented Fax through a VoIP Gateway successfully.
    We are using the Patton SN4114 for the VoIP Gateway and a HP PageWide Pro 577dw MFP as the printer.
    I see the incoming call ring and auto answer but the fax transmission fails.
    Any thoughts or suggestions?
    10,443
    235
    Additional information would be helpful. ATA involved? Is that the Patton , or it it a trunk gateway? Are you certain that your provider supports fax? Is the 3CX extension a "fax extension"? This is all local to the 3CX server?
  3. ntnetzeband
    Jul 30, 2016
    65
    5
    Okay, I've gotten most of it figured out. I can receive faxes but can't send them. The Patton is connected to the printer, no ATA and I'm using a fax extension and my provider supports fax. I am getting a 488 not acceptable here error now when sending. I see some forums on 3CX about it but don't see any resolutions.
  4. leejor
    10,443
    235
  5. ntnetzeband
    Jul 30, 2016
    65
    5
    It turned out to be an issue with our service provider. Thank you for the quick response though!
  6. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    4,891
    321
    Glad to the see the issue has been resolved and thank you for updating the post with your solution
