FAX
Discussion in '3CX Phone System - General' started by rico06, Jan 23, 2008.
  1. rico06
    rico06 New Member
    Jan 11, 2008
    143
    I plan to by a mullticopy fax machin RICOH they telle me its full compatible T38, does it mean I dont need to use a gatway and the Ricoh will be like an IP phone ???
    I am sorry my question is maybe stupid...
  2. 5qg4
    5qg4 Active Member
    Jan 31, 2007
    643
    V5 should be support incoming FAX ONLY.
    For FAX via traditional T.38 FAX machine for incoming and out going. We still using direct PSTN telephone line. The current version V5 build 3790 should be NOT fully support traditional T.38 FAX machine. Please correct me if I'm wrong.
  3. rico06
    rico06 New Member
    Jan 11, 2008
    143
    I think I am going to forget to think to use 3CX with fax because I catch nothing !!!
    Do I need a converter box with FXO FXS
    Do I need a fax T38 compatible
    If someone send me a fax from a T30 fax to a my sip number attach to the 3cx what happened
    if someone can explain me clearly what I need I will be very pleased
  4. matthijsolislagers
    matthijsolislagers New Member
    140
    You just need to buy a SUPPORTED SIP ATA. It should work fine. At least, it does for me.
  5. rico06
    rico06 New Member
    Jan 11, 2008
    143
    ok thanks, witch one do you use ?
  6. matthijsolislagers
    140
    The Grandstream Handytone
