Faxing clarification
Discussion in '3CX Phone System - General' started by pickpro, Oct 27, 2008.
  1. pickpro
    Oct 27, 2008
    I am thinking about implementing 3CX for a client and I'm trying to get some further information on the faxing portion included in commercial versions. Does the fax server in 3CX emulate a modem? Just wondering what is keeping me from deploying Windows Fax services myself with a fax modem to elimanate the need for a commercial license just to support faxing. What else does the commercial faxing addition give me? Just integration with the 3CX managment interface?
    Thanks in advance -
    Greg
  2. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,892
    192
    You can ofcourse use a fax modem but you will have to connect it directly to the PSTN line and bypass the VoIP system. With 3Cx it works via the gateway which is of course much nicer.
  3. pickpro
    Oct 27, 2008
    So with the comercial product no fax modem is needed? It emulates a modem and handles faxing directly?
  4. galal202
    galal202 New Member
    Jun 23, 2008
    235
    Yes, it works with out any modem and save the fax as pdf file
  5. Nick Galea
    Jun 6, 2006
    1,892
    192
    Yes, the VoIP Gateway will receive the fax. Please read the manual which gives a clear overview of how it works...
