Faxing with an ATA
Discussion in '3CX Phone System - General' started by giwm, Mar 10, 2017.
  1. giwm
    giwm New Member
    Sep 27, 2016
    238
    42
    I have a SPA112 hooked up to a fax machine. I set up a Fax extension and configured the SPA112 successfully. I can send a fax without issue, but cannot receive. Like it doesn't even get to the ATA.
    My gut is telling me it's something to do with the inbound rule. I have it set to "Send FAX to" and then the fax extension.
    I don't want to buy a Welltech just to have that fail as well. Especially since I can only find one vendor for those, like they're well past EoL.
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,397
    273
    Do not use "Send Fax To" as that means 3cx is receiving it. Just send the DID to the extension if you want the fax machine to answer.
  3. giwm
    giwm New Member
    Sep 27, 2016
    238
    42
    @craigreilly
    I'm assuming that means I should not set this up as a FAX extension either then, even though that page says, "These are FAX machines connecting via an ATA or a 3rd party FAX software." Because you can't point a DID to a FAX extension.
  4. craigreilly
    Feb 1, 2012
    3,397
    273
    perhaps v15 has changed... my apologies.
  5. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,326
    448
    Hello @giwm
    You should use Fax extensions and use those to register your ATA device. Make sure your configuration is correct and go to Dashboard/ system Extensions and check if the Fax extension you created shows as registered. If it does then your FAX extensions is registered. In the inbound rules you should use the option Send Fax to and direct that to the Fax extension. If that does not work you can set the inbound rule to a normal extension and call your FAX number to see if it will ring. If it does then i would look at the configuration of the ATA.
  6. Chris ODaniel
    Jul 10, 2017
    Is your SPA112 working with v 15.5? Trying to set mine up. Wasn't sure if it was going to work or not. Did you ever get yours working?
  7. giwm
    giwm New Member
    Sep 27, 2016
    238
    42
    Nope, I abandoned the idea. Our SIP provider (nexVortex) also offers a really flexible fax service that we're using instead. No one noticed the change.
