Faxing with Dialogic gateways
Discussion in '3CX Phone System - General' started by kliker, Mar 20, 2009.
  1. kliker
    Mar 16, 2009
    8
    I have installed a 3CX fax server as it was written in manual, but it doest work.
    When trying to send fax, I can make fax message (from Fax console) and send it, remote fax server starts to negotiate a call, but after 3 seconds call is dropped and Fax console says "Fatal error" in Extended status field. When I try to send fax to my mobile phone (for testing) there is no characteristic "peep" sound on the other side when I pickup the call.
    Also, when I try to receive fax message, Server Activity log says:
    Code:
    12:03:29.266  [CM500002]: Unidentified incoming call. Review INVITE and adjust source identification:
      INVITE sip:626@172.16.10.93;user=phone;transport=tcp SIP/2.0
      Via: SIP/2.0/TCP 172.16.254.2:5060;branch=z9hG4bK4550F2D950D017B75D3C435B487C1453
      Max-Forwards: 70
      Contact: <sip:0994697603@172.16.254.2:5060;transport=tcp>
      To: <sip:626@172.16.10.93;user=phone>
      From: <sip:0994697603@172.16.254.2:5060;user=phone>;tag=699D324631353641001BCE74;vnd.pimg.port=1
      Call-ID: 01B229D45F81400000000069@DMG.corp.tech.hu
      CSeq: 1 INVITE
      Expires: 120
      Allow: INVITE, ACK, OPTIONS, BYE, CANCEL, REGISTER, INFO, COMET, PRACK, REFER, SUBSCRIBE, NOTIFY, MESSAGE
      Supported: replaces, early-session, 100rel
      User-Agent: PBX-IP Media Gateway
      Content-Length: 0
    12:03:29.266  [CM302001]: Authorization system can not identify source of: SipReq:  INVITE 626@172.16.10.93 tid=4550F2D950D017B75D3C435B487C1453 cseq=INVITE contact=0994697603@172.16.254.2:5060 / 1 from(wire)
    What could be the problem?
    Regards,
    Boris
  2. instantexpert
    Dec 2, 2008
    92
    Re: Problems with faxing
    What kind of gateway are you using? I'm having troubles with a Patton 4114 not sending faxes and I have an open support ticket on it.
    However, as best as I can tell from your excerpt, you are trying to send faxes using your sip trunk. The last time I looked, 3CX's documentation stated that sip trunk faxing is not a supported configuration. That said, if someone could make it work with my provider, I'd be more than happy to listen. ;)
  3. kliker
    Mar 16, 2009
    8
    I'm using Dialogic 2030 gateway.
    Regards,
    Boris
  4. Nick Galea
    Nick Galea Site Admin
    Jun 6, 2006
    1,889
    190
    Fax is only tested and supported on Patton, Grandstream and Audiocodes gateways.
  5. kliker
    Mar 16, 2009
    8
    Thanks Nick.
    Regards,
    Boris
  6. Nick Galea
    Jun 6, 2006
    1,889
    190
    However please note that RC1 of 7.1 has a problem with fax which we are currently fixing. So if you are using 7.1 RC1 - you are welcome to try RC2 - it may fix it.
  7. kliker
    Mar 16, 2009
    8
    Hi Nick,
    I'm using 7.1.6064 10 (RC1). Where can I download RC2?
    Regards,
    Boris
  8. Nick Galea
    Jun 6, 2006
    1,889
    190
    Its not available yet, any day now. Only pending issue is outbound fax in fact!
  9. kliker
    Mar 16, 2009
    8
    Fax sending worked after upgrade to RC2, but still cannot receive fax. :roll:
    When trying to receive fax, 3CX displays same message as before. Is it possible that I didn't configured 3CX properly?
    888 is FAX server extension number, authentication ID and password. I have configured inbound rule for extension 626 to send fax to email of extension which is 888 by default. Did I miss something?
    Regards,
    Boris
