- Joined
- Nov 2, 2011
- Messages
- 5
- Reaction score
- 0
Hi all,
from the beginning of this installation i am trying to put up an fax extension.
I am running on the V10 SP5, system is running fine. Except for the fax server.
Note: we are not using the mailbox for any extensions except on the faxserver.
This is the error i got in the event log:
The description for Event ID '-1073741822' in Source '3CXFAXSrv' cannot be found. The local computer may not have the necessary registry information or message DLL files to display the message, or you may not have permission to access them. The following information is part of the event:'Service procedure error: Cannot load program configuration. Invalid server address: 192.168.2.100. Local IP not found'
3CX server is running on an Windows 2003 Server, 2 nics, RAS, Exchange, DNS and DHCP.
I think the problem is that the faxserver cannot connect to the mailserevr (localhost), i have tried severall configurations, regading DNS names and IP adresses. None of this was working. And every time i am getting the same error log. Even when i put in the dns name from the domain MX record.
I hope there is someone who can help me with this problem.
Regards, Hafies.
Grt. Hafies
Regards, Hafies.
Grt. Hafies
