Feature code for recording calls
net11
I'm using AASTRA 6731 phones that do not have record btn, so can the recording call feature be accessed with a code.
Do anyone know what the code is or how to progam it?
Hi, assuming that your phones are connected to the 3CX Phone System, if this is the case, then 3CX can record all the calls automatically for you.
Thanks for the reply David, yes all my phones are connected to 3CX. I know that the 3CX will record automatically all calls but can I set up a feature code/access code to turn record on and off for per station?
No, there is not an option to dial a code to record calls.
Regards
Dave
Getting Started - Admin
MattS
Get 3CX - Absolutely Free!
3CX
