Feature Request: Digital Receptionist - Invalid Input Loop
Discussion in 'Ideas' started by Andreas Ioannides, Feb 2, 2017.
Feature Request: Digital Receptionist - Invalid Input Loop 5 5 1votes
5/5, 1 vote
  1. Andreas Ioannides
    Feb 2, 2017
    Dear development team,
    The Digital Receptionist of v.15 allows the call to time out after x minutes when no input is entered.
    However, when the input is invalid and if the option "Repeat Prompt" is selected, then a possibility denial of service exists.
    If the user repeatedly enters invalid input, the Digital Receptionist will repeat the prompt indefinitely.
    A countermeasure is to allow the configuration of certain amount of retries when repeating the prompt.
    Regards,
    AI
