Implemented feature request - force call recordings
Discussion in 'Ideas' started by itsadamr, Nov 9, 2017.
Implemented feature request - force call recordings 4.9 5 55votes
4.9/5, 55 votes
  1. itsadamr
    Nov 9, 2017
    5
    I'm utilizing 3cx in a call center scenario and we've found that users have the ability to turn off call recording through the 3cx client. This is a problem for us as we need all calls to be recorded from the corporate phone system. Please give admins an option to disable control of call recordings for users.
    mobius, billthenerd, godsom and 2 others like this.
  2. the60
    the60 New Member
    Oct 21, 2011
    117
    61
    WHAT????
  3. Silly English Kniggit
    Sep 13, 2017
    220
    89
    Yes, yes, a thousand times yes. Either for calls based on extn, or based on a call flow such as a queue they came through. We get asked this a lot - we've lost business because we'd have to buy additional 3rd party recorder as well as 3cx.
    naveensenapathy likes this.
  4. the60
    the60 New Member
    Oct 21, 2011
    117
    61
    I need to see this. I know that if a call is recorded, the app record light is "lit", but had no idea that it can be turned off. Have you checked rights?
  5. Silly English Kniggit
    Sep 13, 2017
    220
    89
    Behaviour differs slightly across versions of PBX and 3CXPhone. The record button on 3CXPhone doesn't always light. Pressing it during recording always used to stop the recording, now it pauses it and if resumed the PBX inserts blank space (for PCI compliance). I have seen instances where pressing the button during auto-recording does not stop recording - but this is not the designed and stated behaviour. IIRC this was a newer client and slightly older PBX. YMMV - I suggest you test with your own system before relying on the outcome.
    IMPORTANT - we need an OPTION to change the behaviour, NOT for the behaviour change to be hard coded by 3CX. Too many people rely on this working as it does now to just change that.
  6. lee3cxp
    Oct 23, 2017
    Would love to see this feature as well: uphold whatever admin selected for recording. If admin selected to record all the time, this should not be overriden by an agent. Agent can stop recording for him/herself but not affect the server recording mechanism.
    Silly English Kniggit likes this.
  7. drives1
    Nov 30, 2017
    5
  8. Eli55
    Jan 2, 2017
    19
    We need this feature too. Users have been turning off recording buttons.
  9. igor.snezhko
    igor.snezhko Active Member
    Jan 7, 2008
    668
    7
    We need this urgently.
  10. nitrox
    Sep 10, 2016
    99
    11
    i need it as well
  11. Anas_xrt
    Oct 3, 2017
    Need it as well. :)
  12. jhonku
    Mar 25, 2016
    33
    6
    We had to move to another softphone in some environments which needs to record 100% of calls.
  13. 3ctech
    Apr 29, 2014
    7
    We have multiple customers that require calls to be recorded unconditionally and the users are stopping them. There needs to be 3 option. 1 record all calls unconditionally. 2. Allow users to start stop if required. 3. Disable call recording.
    UE@Work likes this.
  14. Serisha
    Dec 13, 2017
    Please could this feature be added? We need it in call center environment and all calls need to be recorded, without the option of the users being able to stop them.
  15. Heinrich Hanekom
    Nov 23, 2017
    UE@Work, MMDTerry and JCLloyd like this.
  16. Techno2018
    Nov 27, 2017
    We really need the ability to on a user by user basis turn off the ability for them to stop and restart recordings.
    +1!
  17. JCLloyd
    JCLloyd New Member
    Oct 5, 2017
    113
    20
    RogerS likes this.
  18. jivetel
    May 1, 2015
    11
    We need this as well.
  19. Marc de Moor
    Dec 14, 2017
    We need this as well....
  20. SouthwestCommunications
    May 23, 2017
    There needs to be 3 options. 1 record all calls unconditionally. 2. Allow users to start stop if required. 3. Disable call recording.
