Feature Request: GSM and 3CX Calls
Discussion in 'Ideas' started by Alen Fazlic, Nov 13, 2017.
  1. Alen Fazlic
    Nov 13, 2017
    Hello 3CX Team,
    unfortunately, we noticed that the calls can not be automatically sent to the voicebox.
    When phoning with the 3CX APP, the GSM calls come with a knock and must be acknowledged or denied.
    Is it possible that GSM calls are automatically sent to voicebox when using the 3CX App is phoned?
    Can you please check the feature and implement when possible?
    regards
    Alen
