Feature Request(s): Saving Window Settings, and others
Discussion in 'Windows' started by darrellchapman, Feb 18, 2008.
  1. darrellchapman
    Nov 26, 2007
    268
    If would be quite convenient if the VoIP client had the following features:
    1) It would save its Window position. Everytime it starts up, I have to reposition it where I want it on my desktop
    2) It could be resized for users running high resolutions
    3) It would save the number of columns I have added for the extension listing
    4) I could selectively add/remove extensions I don't want shown in my client.
    Thanks so much,
    Darrell Chapman
  2. aguilar
    aguilar New Member
    Jul 19, 2007
    169
    i agree with Darrell, this would make the use easier
    regards
