Feature Request - Skip voicemail greeting
Discussion in '3CX Phone System - General' started by choimarc, Aug 26, 2014.
  1. choimarc
    Feb 19, 2014
    77
    8
    We are well please with our 3CX system for now. However there is one major irritant that we have and it's not being able to skip the voicemail message when going into someone's voicemail. I even had a client tell me that my phone system was broken because he's hitting the # to skip the message and gets disconnected.
    Please add this feature. :)
    Thanks.
    dsmith_ECS likes this.
    11,086
    325
    This is where you'll have to go to submit a feature request... http://www.3cx.com/ideas/index.php
  3. choimarc
    Feb 19, 2014
    77
    8
    thanks, will do.
