Feature Request: Supporting Unify Openstage phones by 3CX
Discussion in 'Ideas' started by WOHLERT.IT, Sep 7, 2017.
Feature Request: Supporting Unify Openstage phones by 3CX 4.4 5 7votes
4.4/5, 7 votes
  1. WOHLERT.IT
    Feb 17, 2016
    7
    A lot of our customers are looking for a PBX which supports Unify Openstage phones for the following reasons:
    - high quality
    - good design
    - changing the PBX from Siemens, Unify or Swyx to 3CX without changing the ip phones
  2. digiteo
    Mar 22, 2016
    17
  3. simply7
    Jan 4, 2016
    40
    20
    Some of those do not use SIP standards and will never be supported. However I don't know much about their other SIP phones whether they would work or not. My guess is that if you are swapping out an old HiPath system using the model 40 phones those will not work. I had one to mess with just to satisfy my curiosity.
    #3 simply7, Feb 1, 2018
  4. Kobberhjelmen
    Aug 1, 2017
    15
    You can replace the HFA software with SIP Software to be able to connect the phones to 3CX, but some features may be limited - And you need to program the phones manually.....
  5. timmbo
    timmbo New Member
    Aug 25, 2017
    107
    49
  6. joe-3cx-user
    May 20, 2018
    12
    Hey, was it working?
