Feature request: when a call ended give sound notification
Discussion in 'Ideas' started by PatrickS, Jan 4, 2018.
Feature request: when a call ended give sound notification 5 5 10votes
5/5, 10 votes
  1. PatrickS
    Sep 25, 2017
    22
    When calling with 3CX, it's unclear when the call is ended if not looking at the screen. The App (android, ios) silently ended the call.
    how about adding a 'sound' when a call was teminated.. (like all default phone call app in android, and iOS)
    ElementalWindX likes this.
  2. Otto Lodewijk
    Jan 4, 2018
    14
    Totally agree on this one! On behalf of our clients / end-users, we collected a lot of feedback and this issue was very high on their lists too.
    A really short beep-beep-beep (such as in the Whatsapp calling fuction) would be more than enough.
    In general, please have the iOS/Android/Windows apps tested and improved for user-friendlyness and user-experience, because a lot of these kind of issues are present in the client.
  3. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,358
    535
    Moving this thread to the ideas section where it can be upvoted
  4. Otto Lodewijk
    Jan 4, 2018
    14
    Thanks!
    Any idea about the implementation speed after this idea is upvoted? And what's the threshold?
  5. Asiri Diaz
    Nov 21, 2017
    11
    Yes,
    When it come to Call center auto answer feature its a must wanted feature for windows client..
    Voting +1
  6. ElementalWindX
    Oct 24, 2018
    16
    +1 for this idea. Plus the buttons on the app need better illustrations as to if they are enabled/disabled. The mute button is a great example as it's confusing to look at. Give it a "depressed" look when muted, and perhaps a red color to it.
    Same for call recording. We auto record all our calls and it should display if this is actually being recorded.
    Also add key press sounds like when dialing numbers. It does it for the first number then after that it's silent.
