Feature Request
Discussion in '3CX Phone System - General' started by tobiastromm, Sep 27, 2011.
  1. tobiastromm
    tobiastromm New Member
    Jun 26, 2010
    138
    The last version of 3CX send email when some extension status change.
    Can 3CX do something to select the extension the system will send e-mail? (Example: just send e-mail when extension 101 and 102 change they status).
    Can 3CX do something to send e-mail for trunks change?
  2. nbailey
    nbailey Member
    Jan 31, 2011
    359
    feature requests go to 3cx.ideascale.com
    Check out notifications in management console > advanced > notifications to see your options. (V10)
    Thanks,
    Nate
