- Joined
- Mar 4, 2008
- Messages
- 5
- Reaction score
- 0
sorry for my bad english.
Simply, I have provider Telekomaustria for VoIP lines. When I use some software VoIP client like X-lite, there is not problem with connectivity to this provider (from the same computer where is 3CX central installed). But I cant to setup the same parameters of VoIP line in 3CX central.
Why?...
For example in X-Lite there are 5 parameters to configure VoIP line:
- Display Name,
- User name,
- Password,
- Authorization user name,
- and Domain
But in 3CX central there are completly only 4 parameters to configure VoIP line:
To configure my VoIP provider:
- Registrar/proxy + outbound proxy (that's two parameters but for my problem it's the same like Domain in VoIP client)
To configure VoIP line:
- External number
- Authentication ID/user name
- Password
The provider Telekomaustria had different User name and Authentication ID, so this two items cannot be fill only in one field. Where can I find the field for specify what is stored in field "Authentication ID/user name" and the field for input the second item??
I supposed that solution is in change items in headers for outbound/inbound communication with provider, but is it? And specifically, how should i do it?
Thanks you very much for your help!
Why?...
- Display Name,
- User name,
- Password,
- and Domain
- External number
- Password
