File format for emailed voicemails that is supported by Chrome
Discussion in 'Ideas' started by Adam Jasinski, Mar 5, 2017.
  1. Adam Jasinski
    Jan 25, 2017
    12
    I apologize if this has already been submitted (searched but didn't see it). As a school we use Chrome very heavily since we use Googles Suite of Apps. Having a WAV format that chrome will not play natively is a bit of pain. Yes, I know my users can download the file and listen to it, but that is easier said than done. It would be great to have the ability to select what type of audio file we want or select an encoding that Chrome will play natively.
    It just seems that the audio files should play in the browser that has the widest adoption rate, which is Chrome.
    Thanks!
  2. ivank
    3CX Support
    Jan 4, 2017
    54
    6
