File queue isn't working after menu choice
cyberlex7
Hello everyone,
Thanks for looking at my problem.
When I reive an external call, there'sno problem until the caller is transferred to the Call Queue after chosing from the auto attendant.
I don't have this issue when i Directly set the redirection to Call queue at the External Line Destination.
Here is the scheme :
Does anyone have an idea ?
Thank you,
Alex.
If it can help, i noticed the following code which may be the cause in server status page :
17:21:33.327 MediaServerReporting::DTMFhandler [MS211000] C:3060.1: XXX.136.161.70:46484 is delivering DTMF using RTP payload (RFC2833). In-Band DTMF tone detection is disabled for this call segment.
Thanks,
Alex.
Hey there,
We've seen problem where having re-invite enabled in the capabilities settings for our sip trunk causes the ivr service to crash when an external caller is connected to a call queue. Similar symptoms to what you're describing I think except that I'm pretty sure we were getting on hold music playing.
See http://www.3cx.com/forums/problem-while-answering-call-from-queue-7577.html for more detail.
Mick.
Hello Mick,
AS you told me in the other post, i tried to disable Re-Invite function but it does not change something regarding tranfer to call queue. No prompt is played.
Thanks for your help,
Alex.
cyberlex7 said:
Hello Mick,
Alex.
What does the server status log say? Any errors?
Mick.
Getting Started - Admin
sd24mi
Get 3CX - Absolutely Free!
3CX
