File to project
Discussion in 'Call Flow Designer' started by gustavskii, Jan 10, 2019.
  1. gustavskii
    Jan 26, 2016
    65
    Hello
    Due to some unfortunate events I have lost all my CFD projects, but I still have all .tcxvoiceapp files
    Is there a way to convert .tcxvoiceapp files to projects?
  2. edossantos
    edossantos Support Team
    Jun 27, 2007
    1,681
    131
    Unfortunately that's not possible, the tcxvoiceapp is ZIP including a compiled DLL, there is no way to go back without the sources.
  3. gustavskii
    Jan 26, 2016
    65
