Filter Call Recordings
Discussion in '3CX Phone System - General' started by Philip Darnell, Dec 2, 2017.
  1. Philip Darnell
    Philip Darnell New Member
    Jan 26, 2017
    158
    10
    Is it possible to filter the call recording in V15.5? So I can see all call recordings for a certain date range?
    they seem to be ordered by EXT. and then date but I need to find all calls to a certain number from all extensions over the last month.
    jlinds likes this.
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,783
    561
    Hello @Philip Darnell
    Please note that there is currently an issue with call recordings sorting that will be fixed in the next update. For now you can use the search bar and search for the number in the recordings list.
    jlinds likes this.
