Firefox Windows 3CX client and Webmeeting
Discussion in 'Windows' started by IT_S, Mar 23, 2018.
  1. IT_S
    Dec 20, 2017
    18
    I am trying to configure and use Webmeeting via 3CX Windows client.
    It works with Chrome however if I launch via Firefox ( version 59) , I cannot log in...
    Log in Button is not available even If I click on it.
    Any ideas on what is wrong ?
  2. LeonidasG
    LeonidasG Support Team
    Nov 19, 2008
    1,473
    94
    Screenshot of the issue?
  3. IT_S
    Dec 20, 2017
    18
    Hereunder screenshot.
  4. LeonidasG
    Nov 19, 2008
    1,473
    94
    Very strange, i don't get this error.
    Could you PM me your FQDN/WebMeeting Portal name?
    Also if you remove your webcam from your PC, does it start working?
  5. IT_S
    Dec 20, 2017
    18
    PM sent.
    No it is same thing with or without webcam...
  6. LeonidasG
    Nov 19, 2008
    1,473
    94
    Just checked it out. Seem to be working fine, so not a server issue.
    Could you disable a few extensions, Clean Cache or re-install firefox?
  7. IT_S
    Dec 20, 2017
    18
    I have tried on another computer and no problem on it...
    However if I block video/audio on mine an I can enter normally.
    Will check what is wrong maybe Firefox reinstallation... will fix it
    Just a quick question, do you know when Remote control and Screen sharing will be available on Firefox ?
