Firewall and public IP
Discussion in '3CX Phone System - General' started by SWSDEV, Apr 15, 2008.
  1. SWSDEV
    SWSDEV Member
    Feb 23, 2008
    256
    my firewall test works just great, except for this one line...
    # Port Status Description Parameters
    1 Error (13) The machine is on a public IP. Please check the FAQ for more information. agentAddr = 87.230.29.162:4200
    Is there supposed to be a problem running 3CX on a public IP? This is the IP that Broadvox is pointing to.
  2. Desiderius
    Apr 8, 2008
    i have the same problem, but find no answers or solutions here.
    If i try it with version 3, everything works fine!
  3. h2009
    h2009 Member
    Mar 15, 2008
    447
    Checked here: http://www.3cx.com/support/firewal-checker.html ?
    and here : http://www.3cx.com/support/nat-firewalls.html
    and here for stun info: http://www.3cx.com/PBX/stun-server.html
    And on a side note, have you turned off windows firewall - try putting the machine in a DMZ, that should fix it.
  4. tekknow
    Oct 3, 2008
    29
    CHeck here
    http://docs.google.com/View?docid=dqnz5cc_44fqd5ffdb
    see the section
    Customisation of Internal/External device detection
