Firewall Check and a new Cisco RV340
Discussion in '3CX Phone System - General' started by Tim H, Dec 21, 2017.
  1. Tim H
    Aug 11, 2017
    7
    I recently replaced my Cisco router because of Errors I was receiving. I selected a RV 340 because I have successfully used this series of a cisco router with errors on other 3CX deployments.
    I have confirmed that SIP ALG is disabled on the firewall configuration screen and configured all of the appropriate ports. However, here are the results I get.
    • resolving 'stun-us.3cx.com'... done
    • resolving 'stun2.3cx.com'... done
    • resolving 'stun3.3cx.com'... done
    • resolving 'sip-alg-detector.3cx.com'... done
    • testing 3CX SIP Server... done
      • stopping service... done
      • detecting SIP ALG... detected (received 7c0c52e1 ≠ 9af17011) (How to resolve?)
      • testing port 5060... done
      • starting service... done
    • testing 3CX Tunneling Proxy... done
      • testing port 5090... done
    • testing 3CX Media Server... done
      • testing ports [9000..9255]... done
        • testing port 9000... done
    Everything passes except the ALG test.
    As I explained earlier, SIP ALG has been disabled on the router and I am not sure where I go from here.
    Ironically SIP ALG passed with my old router but I had intermittent failures under the media server.
    Any thoughts? I have a SG300 Series Switch and a SF300 Series switch in the mix too.
  2. viraltechnology
    Mar 22, 2015
    39
    6
    some of those you will have to disable dos and spi to completly get rid of sip alg.
