Firewall checker doesnt work
Discussion in '3CX Phone System - General' started by SFX Group, Jun 23, 2011.
  1. SFX Group
    Jun 20, 2011
    16
    Hi all
    Server 2008 (64bit)
    3CX v10.0.19547.1805 sp1.1
    See enclosed image, i stop this service (tried both manually in the services in server and via the web management), when i press "firewall checker" i get that "need to stop" services error..... it is stopped, so how do i test the firewall?
    Many Thanks
    Ashley
  2. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,083
    10
    It looks like you stopped only the 3CX tunneling service and not the main 3CX PhoneSystem service (the second in the list on the image attached).
  3. eckho88
    Jun 15, 2011
    For User the Firewall Checker, U Need Stop 2 services = "3CX PhoneSystem" and "3CX PhoneSystem SIP/RTP Tunneling Proxy".
    To get access to services menu, u can follow this steps => Start > Run > Services.msc > Done.. ;)
  4. SFX Group
    Jun 20, 2011
    16
    Thanks, got it working now :)
