Firewall Checker Issue / Curiosity
Discussion in '3CX Phone System - General' started by OldJames, Nov 30, 2009.
  1. OldJames
    Nov 30, 2009
    7
    Just giving 3cx my first kick at the can. In running the Firewall Checker, phase 2a fails immediately.
    Code:
    <16:54:46>: Phase 2a,  Check Port Forwarding to UDP SIP port, please wait...
    <16:55:06>: UDP SIP Port is set to 5060. NO RESPONSE received. Phase 2a check FAILED.
    Application exit code is -2
    However, if I randomly change the ports on the Firwall Checker prompt to 5067:
    Code:
    <16:55:43>: Phase 2a,  Check Port Forwarding to UDP SIP port, please wait...
    <16:55:58>: UDP SIP Port is set to 5067. Response received correctly with no translation. Phase 2a check passed.
    <16:55:58>: Phase 2b. Check Port Forwarding to TCP SIP port, please wait...
    <16:55:58>: TCP SIP Port is set to 5067. Response received correctly with no translation. Phase 2b check passed.
    This is 3cx free on a windows XP box. The router/firewall is just a consumer grade D-Link (DIR-655).
    Port Forwarding is setup in the router for 5060 TCP/UDP, 5090 UPD, and 9000-9005 UDP
    using ip range 10.0.0.x / subnet 255.0.0.0 ( if that helps)
    Since the 5067 attempt doesn't even have the port forwarding set in the router, so strange...
    Any ideas or assistance appreciated.
  2. jelliott52
    Oct 21, 2009
    28
    Just a guess, but do you have any outbound rules setup? Most firewalls/routers allow all outbound unless you have a rules setup.
    Jay
  3. KerryG
    KerryG Active Member
    Jun 19, 2009
    960
    I use a DIR655 as well and it only needed simple forwarding options set. Are you sure your ISP is allowing 5060 to come through? Some block that port.
  4. OldJames
    Nov 30, 2009
    7
    Actually Kerry, what I found is that if I removed all Port Forwarding from the DIR-655, the firewall checker completed 100% successfully.
    Really strange. It seems that having the port forwarding set up is what was causing the issue.
    If you have a screen shot of your forwading rules, I'd certainly take a peek.
  5. KerryG
    Jun 19, 2009
    960
    Here is my settings, note also I do NOT have DMZ enabled.
    [​IMG]
  6. OldJames
    Nov 30, 2009
    7
    Thanks Kerry. Much Appreciated.
    They appear to be similar setting to what I had, although I bulked more ports into a single rule.
    The 3cx system works fine without them (which I don't get), but I'll try to set it up your way and see what happens.
