Firewall Checker - some ports open, most closed
Discussion in '3CX Phone System - General' started by redhamilton, Jun 10, 2016.
  1. redhamilton
    Jan 22, 2016
    10
    Sonicwall NSA 4500 - with required "disable source port remap" hotfix
    One to One NAT
    different External/Internal FQDN
    No idea what is going on.
    NAT and Firewall access rules setup correctly. All VoIP functionality in firewall disabled.
    Going Line by line in firewall checker...
    Port 5060 open
    Port 5090 closed
    Port 9000-9005 open
    Port 9006-9255 closed
    All of the above ports are open at teh firewall..
    This makes no sense.
    Any insights?
  2. complex1
    complex1 Active Member
    Jan 25, 2010
    815
    49
    Please disable the Windows Firewall and test again.
  3. redhamilton
    Jan 22, 2016
    10
    Ah yes, I knew I was forgetting to post something obvious.
    Yes, I've already made sure windows firewall is off....did that before even starting this.
  4. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,575
    305
    Do you have an outbound SNAT? I found that helped in my prior Sonic Wall setups.
  5. redhamilton
    Jan 22, 2016
    10
    I do not.
  6. complex1
    Jan 25, 2010
    815
    49
    I do not use the Sonicwall NSA 4500, but when reading the “how to config” of the SonicWALL I am wondering why you don’t use the “Many-to-One NAT” config.
    I think this is a better setup. Don’t ask me why.
    http://www.3cx.com/blog/voip-howto/soni ... iguration/
  7. redhamilton
    Jan 22, 2016
    10
    Well, I used a One-to-one simply because I could. I have a few available Public IP's, so why not dedicate one. I'll try a many to one, since thats the scenario 3cx uses to describe setup with a sonicwall. If that doesn't work I think I'll try putting it in a DMZ.
  8. redhamilton
    Jan 22, 2016
    10
    Just reporting back in. Figured the issue out.
    Thanks for the help.
    -Josh
