Firewall checker w/o STUN
Discussion in '3CX Phone System - General' started by dlazure, Jan 11, 2013.
  1. dlazure
    Nov 5, 2012
    65
    hi
    I ran the Firewall checker to see if my port fowarding are correct and i also have disabled the STUN request because my public ip address never change but each time i run it it try to resolve my ip address with STUN server and get the wrong one... is it normal that it try with stun server even if i turned it off?
    lets say my address is 205.143.234.120 STUN server resolve 205.143.234.122 and fail all the port test
    we fowarded port 5060,5090, 9000 to 9049 to the pbx, we disabled sip alg
    what should we do?
  2. mixig
    mixig Active Member
    Dec 13, 2011
    519
    11
    do you have mulitple ip addresses on your router/firewall or more then one Internet link? if you open web browser from computer where 3cx is and go to this page http://www.whatismyip.com/ what is you ip?
  3. 3CXfoxhallsolutions
    3CXfoxhallsolutions New Member
    Sep 8, 2012
    211
    Sounds like you have a block of routed IP addresses configured in your firewall / router.
    Are you setting your 3CX LAN NIC to be on one of these routed IP's - or is it on a LAN IP address (either static or DHCP)??
    best regards
