Firewall Checker
Discussion in '3CX Phone System - General' started by pstmg, Dec 9, 2012.
  1. pstmg
    Dec 9, 2012
    49
    Hello all,
    I've installed the 3CX Phone System and before configure the remote clients, I did a firewall check. The results are bellow:
    Testing SIP Port 5060 using STUN server: stun.3cx.com:3478
    Resolving STUN server stun.3cx.com ... Resolved to: [199.192.206.228]
    [Test1] Reachability test ... Resolved Public IP: 123.456.789.100:63426
    STUN server stun.3cx.com has second address 199.192.206.229:3479
    [Test2] One on One Port Forwarding ... OK.
    Testing Tunnel Port 5090 using STUN server: stun.3cx.com:3478
    [Test1] Reachability test ... Resolved Public IP: 123.456.789.100:54141
    Testing External Audio RTP Port 9000 using STUN server: stun.3cx.com:3478
    [Test1] Reachability test ... Resolved Public IP: 123.456.789.100:61775
    Testing External Audio RTP Port 9001 using STUN server: stun.3cx.com:3478
    [Test1] Reachability test ... Resolved Public IP: 123.456.789.100:62440
    Testing External Audio RTP Port 9002 using STUN server: stun.3cx.com:3478
    [Test1] Reachability test ... Resolved Public IP: 123.456.789.100:57827
    Remote clients can register (ip phones) however there is no audio in both ways.
    The phone system is conected to a broadband router with fixed IP and open ports towards the server.
    Could you please help me with this issue?
    Regards
    Paul
  2. mixig
    mixig Active Member
    Dec 13, 2011
    524
    12
    Try with this... i solved my problem with that link...
    http://www.3cx.com/blog/voip-howto/remote-extensions/
  3. pstmg
    Dec 9, 2012
    49
    Thanks for your reply. today I have the system up and running on external: Linksys PAP2 and Airlive IP Phone. the problem was the stun server that was activated on the server side.
    In the meantime I hereby send the link of the IP Phones I use !!
    http://www.airlive.com/product/ePhone-1000S
    Cheers,
    Paul
  4. leejor
    10,859
    301
    You are sending an engraved invitation to hackers by posting your full public IP. I would suggest editing your previous post to X out some of the digits.
  5. pstmg
    Dec 9, 2012
    49
    Well, thanks for your concern. but obviouly this is NOT my IP. It was made up. the other data is real.
    Cheers,
    Paul
