Firewall Checker
Discussion in '3CX Phone System - General' started by petewatterschats, Feb 28, 2016.
  1. petewatterschats
    petewatterschats New Member
    Jan 19, 2016
    151
    Firewall Checker
    Setup port forwarding, firewall checker gave errors on ports 9000-9255
    every 21 port gave error "no response received or port mapping is closed - Port forwarding not configured correctly"
    Ports 9256-9500 not checked by firewall checker
    Use Liksys example as a guide for setting up port forwarding
    11,079
    324
    How many ports you open in the 9000 range all depends on how many VoIP channels, and services, you plan on using. If it is a simple system, then you won't use all of them.
    http://www.3cx.com/blog/docs/ports-used/
    I just do 9000 to 9049 , which is sufficient (used to be the 3CX default a while ago) for basic VoIP traffic. I believe it is two channels per call.
    Some ports may be "intercepted" by other processes running on your system.
