Firewall checking fails for SIP port and tunnel (5090)
Discussion in '3CX Phone System - General' started by Vaucluse, Jan 26, 2015.
  1. Vaucluse
    Sep 30, 2013
    14
    With V12.5 the firewall checker fails for the SIP port and the tunnel. (V12 has no problem)
    OS: windows 7 Pro with windows firewall and 3CX Web server.
    It looks like the test connections are made to C:\Program Files\3CX PhoneSystem\Bin\Webserver\adn\FCGIDotNet_4_0_x64.exe
    instead of using 3CXPhoneSystem.exe and 3CXTunnel.exe.
    Is this a known issue? Any solution?
    Regards,
    Marcel
  2. pabarnes
    Apr 3, 2015
    Recommend you check your exception in the Firewall settings for 3CX.
