Firewall Ports
Discussion in '3CX Phone System - General' started by andrew.doades, Dec 10, 2010.
  1. andrew.doades
    Dec 10, 2010
    8
    We're setting up a new 3CX phone system and I've found the page below for the firewall ports:
    http://www.3cx.com/manual/3CXPhoneSystemManual31/phone-system17.html
    What I need to know is are these the ports to open for incoming calls?
    Andrew
  2. davidbenwell
    davidbenwell Active Member
    Apr 27, 2010
    704
    Port 5060 contains the Call Header Info
    Ports 9000+ supply Audio / Video
    So you need to open all ports for calls in and out to work
  3. complex1
    complex1 Active Member
    Jan 25, 2010
    814
    49
    There is a good article here on the 3CX site about how to configure a firewall.
    http://www.3cx.com/blog/voip-howto/firewall-configuration-overview/
    The next ports must be opened/forwarded to the 3CX Server
    5060 TCP/UDP
    5090 TCP/UDP
    9000~90xx UDP
  4. davidbenwell
    Apr 27, 2010
    704
    Remember that when doing port forwarding or allowing ports in via the firewall to allow two ports per call
    So f your VoIP provider allows you to make / receive upto 10 calls at any one time then you will need to open 20 ports
    9000 to 9020 UDP
    3CX default is 9000 to 9049 so that will allow you to make 24 Calls
