Firewall Ports
Discussion in '3CX Phone System - General' started by mfretwell, Aug 14, 2008.
  1. mfretwell
    May 26, 2008
    25
    System
    VOIP: Vonage (Canada); stunserver.org
    PBX: 3CX v 6
    Firewall: SonicWall 2040 Pro
    Phones: Aastra 55i
    Problem
    We are having problems with stunserver timeout, and our line not registering.
    I suspect that it is a firewall issue.
    Question
    Can anyone tell me which services need to be enabled and which ports need to be opened on the SonicWall firewall to effectively allow VOIP communication?
    A deceptively simple question 8)
  2. amygoda
    amygoda Member
    Sep 18, 2006
    436
    Hello
    You can find full details in the manual
    http://www.3cx.com/manual/3CXPhoneSystemManual6/phone-system15.html
    But You have to know Your voip provider settings
  3. francesco
    francesco New Member
    Jun 23, 2008
    102
    firewall test of 3cx is ok?
  4. mfretwell
    May 26, 2008
    25
    You betcha.
  5. mfretwell
    May 26, 2008
    25
    Lines and extensions registered now. Had to change VOIP setting on SonicWALL to "Permit non-SIP packets on signaling port" (see image below).
    BUT we still only get one-way audio :cry:
    AND we are still getting STUN server timeouts :roll:
  6. ess
    ess New Member
    Jun 8, 2007
    133
    I got my stun server timeouts when I had two network interfaces installed on the machine (one lan, one hamachi). At this time, 3cx is most stable when you only have one network interface.
  7. mfretwell
    May 26, 2008
    25
    Have only one NIC with no other networking devices installed.
  8. worksighted
    worksighted New Member
    Aug 19, 2008
    204
    Which direction are you getting the audio in?
  9. mfretwell
    May 26, 2008
    25
    We get audio out but not in.
  10. francesco
    Jun 23, 2008
    102
    you can try to specify port 5060 on sonicwall (not 5061)
