firewall problem
Discussion in '3CX Phone System - General' started by landfiets, Nov 2, 2007.
  1. landfiets
    landfiets New Member
    Jul 17, 2007
    243
    Hi, since a few weeks I get a delay in the audio from internal to external.
    When people call us there is no problem.
    [MS101003] Call(55) Ln:10000@Voipdiscount: Possible firewall problem. Address mapping failed on STUN server 194.221.62.209:3478 for local address ":9000"
    is it a port problem? Or what? I consider all ports to be open. I did that allready months ago and it was working fine at that time.
  2. RobLloyd
    RobLloyd Member
    Oct 13, 2006
    481
    Looks like your NAT isn't working properly. It's only showing the final port :9000 not 192.168.1.1:9000 or some real IP address.
    Check your router and your firewall again.
  3. landfiets
    Jul 17, 2007
    243
    firewaill
    okay. But whereshould I look in the router. All the ports are open.
    Tell me where to look please
