Firewall Tester Tests Unnecessary Ports in v15
Discussion in '3CX Phone System - General' started by jms, Sep 29, 2016.
  1. jms
    jms
    May 23, 2011
    42
    I don't want to have 256 RTP ports when I will never use most of them. If you run the firewall tester, it takes too long and that time is downtime.
    I have a v15 site with 100 RTP ports: custom parameter FIRSTEXTPORT is 9000 and LASTEXTPORT is 9099.
    When I run the firewall checker, it checks ports 9000 to 9255.
    The firewall checker could be finished 60% quicker if it tested the correct port range.
  2. craigreilly
    craigreilly Well-Known Member
    Feb 1, 2012
    3,401
    273
  3. Sopock
    Sopock Member
    Jul 11, 2012
    447
    20
  4. Sopock
    Sopock Member
    Jul 11, 2012
    447
    20
    I guess only option is to open all ports and then change it again?:confused:
    If everything is configured correctly, the tests should take less than a minute. If there are issues with all the ports, the test can take between 4 and 9 minutes. You also have the option to cancel the test.
    Dot alignment?
    • resolving 'stun.3cx.com'..... done
    • resolving 'stun2.3cx.com'... done
    • resolving 'stun3.3cx.com'... done
    • testing 3CX SIP Server...... done
      • stopping service...... done
      • testing port 5060..... done
    #4 Sopock, Feb 4, 2017
  5. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
  6. craigreilly
    Feb 1, 2012
    3,401
    273
    it doesn't really matter. my machine fails the firewall checker but we have no issues. every time we run the checker different ports fail in the 9000 range. the same firewall passed in v14.
    just open the ports you need.
