Firewall trying to register with 3CX system.
Discussion in '3CX Phone System - General' started by pogue1000, Jul 15, 2011.
  1. pogue1000
    Jun 1, 2011
    21
    Well, finally purchased me a 16 user license and testing out the system some more and in my server event log i am seeing the following error
    The IP 192.168.1.1 has been blacklisted for 1800 sec. Reason: Too many failed authentications!
    192.168.1.1 is the internal IP address of my firewall. Curious why my firewall is attempting to register with the system?
  2. eagle2
    eagle2 Well-Known Member
    Apr 27, 2011
    1,085
    11
    Most probably it is an attack outside.
    Your firewall / NAT are probably not set correctly, that's why you see the internal address.
    Can you debug / see logs of the router ?
