Solved firmware Aastra 6730i (up to date)
Discussion in '3CX Phone System - General' started by rsamaniego, Aug 11, 2017.
  1. rsamaniego
    Aug 11, 2017
    5
    Hi, I have installed the v15 and I have provisioned a Aastra 6730i puts firmware version 2.5.2.1010 (Up to Date) instead at https://www.3cx.com/sip-phones/aastra/ it appears that the last firmware is 3.3.1.4305.
    if I follow the instructions to update it tells me to copy the firmware here:
    C: \ ProgramData \ 3CX \ Instance1 \ Data \ Http \ Interface \ provisioning \ XXXXXX.
    That folder no longer exists should. I must upgrade using a tftp own server?
    thanks
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,350
    452
    Hello @rsamaniego
    Is there no folder under C: \ ProgramData \ 3CX \ Instance1 \ Data \ Http \ Interface \ provisioning \ ?
    There should be a folder with a random generated name that contains firmware folders and other files necessary for the operation of the PBX.
    Extract the contents of the .zip into the folder and follow the guide
  3. rsamaniego
    Aug 11, 2017
    5
    thanks, it´s ok.
