Firmware Directory?
Discussion in '3CX Phone System - General' started by JST, Jan 9, 2017.
  1. JST
    JST New Member
    Jan 8, 2017
    107
    I am using a Yealink T22P and 3CX is showing a newer firmware on the provisioning page. For various reasons, I would prefer to do a manual firmware upgrade.
    Where can I find the firmware file on my debian installation? Thank you!
  2. GiannosC_3CX
    GiannosC_3CX Guest
    Dear @JST ,
    Here is the path of the downloaded firmware on debian /var/lib/3cxpbx/Instance1/Data/Http/Interface/provisioning/%%PROVSUBDIR%%/firmware_new/yealink
  3. JST
    JST New Member
    Jan 8, 2017
    107
    Thank you! I will now work on retrieving the firmware from there.
    Just a suggestion: It would be nice to have a simple download button for the firmware. This way people could just do a manual upgrade if they choose to do so.
  4. JST
    JST New Member
    Jan 8, 2017
    107
    Here is what I did to download the firmware to my local desktop.
    1. Use console and locate the firmware as outlined in the post above.
    2. Copy firmware <YOUR_FIRMWARE> to /var/lib/3cxpbx/Data/Http/wwwroot/
    3. https://<YOUR 3CX IP>:5001/<YOUR_FIRMWARE>
    4. Download firmware.
    This seems to be the easiest solution with my rather limited Linux skills. :)
    Hope this will help someone else.
  5. GiannosC_3CX
    GiannosC_3CX Guest
    Glad to hear that you find this way that suit on your requirements and thanks for sharing.
  6. Sopock
    Sopock Member
    Jul 11, 2012
    447
    20
    You can also locate the firmware by using favorite SFTP client like WinSCP or Fetch:cool:
  7. David Glandorf
    Apr 12, 2017
    5
    I'm trying to connect with WinSCP but what are the settings?
  8. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    6,350
    450
    Host name is the IP of your installation, the port number should be 22
    The username of the user that installed the PBX and the password.
    Leave the file protocol to SFTP.
