Firmware upgrades
Discussion in '3CX Phone System - General' started by st1172, Aug 18, 2016.
  1. st1172
    Aug 18, 2016
    What process needs to be followed to get firmware to push out to Cisco SPA series phones that had compatible firmware in previous versions? The latest information I can find states firmware 7.6.1 is supported, yet it cannot be downloaded from 3CX and putting the files in the firmware folder does nothing. Please advise on this undocumented feature.
  2. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    5,486
    357
  3. CentrexJ
    CentrexJ Member
    May 5, 2009
    420
    62
    Take note of this information:
    "In case the defined version of the firmware is not installed, manually update the firmware before proceeding. When upgrading a Cisco SPA50X or Cisco SPA30X IP phone firmware version prior to 7.5.2b, you must first upgrade to 7.5.2b before you upgrade to 7.6.1."
    If you firmware is older than 7.5.2b you have to first upgrade it manually on each phone and then you can use 3CX to upgrade to the newer firmware.
