First Call Works - Second no Audio
Discussion in '3CX Phone System - General' started by micahcw, Apr 17, 2011.
  1. micahcw
    Apr 17, 2011
    6
    When I make an external call via one of my voip providers the first call works fine, inbound and outbound Audio both work. I then hang up and redial, however the outbound Audio on the second call is almost non-exisitent, very jittery with a massive lag.
    However if I restart the 3cx services I can then make 1 good call again.
    I have looked at the server logs and both the first and second calls look identical.
    I have run the firewall check and come back no errors.
    I am running 3cx on VMWare ESXi. I have followed the virtual machine setup guides.
    I am not quite sure what else I should be even looking for, any advice would be appreciated.
    MJ
  2. smb1
    smb1 New Member
    Mar 18, 2009
    104
    Can you perform a Wireshark capture of a call and post that here. It may help with identifying the issue.
  3. micahcw
    Apr 17, 2011
    6
    I have attached a pcap of the good call. I will post again with the pcap of the bad call.
    Cheers
    Micah
  4. micahcw
    Apr 17, 2011
    6
  5. micahcw
    Apr 17, 2011
    6
  6. micahcw
    Apr 17, 2011
    6
    Hi people,
    I have narrowed this down to the Media Server service. AFter rebooting the media server service, I can make my 1 good phone call.
    However if I disable the media Server service I don't get the problem in the first place, nothing to do with firewall / NAT.
    I have uninstalled v9 and installed v10 beta II with the same issue.
    Does anybody even know what the media server service does?
  7. micahcw
    Apr 17, 2011
    6
    I have worked around this, it looks to be something to do with transcoding bound mode;
    as a work around I have disabled the media server service, I did find the below link to help me out a bit.
    http://www.3cx.com/blog/docs/media-server/
