First Post - Easy now :)
Discussion in '3CX Phone System - General' started by jackpod, Aug 15, 2010.
  1. jackpod
    Aug 13, 2010
    First post... I sucessfully have 3cx talking to my cisco 2651 w/2 FXO and 2 FXS (only have 1 pots line coming into the house and the cisco is also doing my DSL authentication and network default gateway) but I have both fxs port connected (1 to physical phones, 1 connected to my way2call connected to Homeseer) I have 4 instances of Xlite on different computers. Calling works in all directions, softphone to outside, outside to softphone, fxs to outside, softphone to softphone. I have the calls currently forwarded to one of the softphones
    my issue. When I setup 3cx, it asked for extensions, fine I did that but I want the incoming call from the pstn gateway to go to the attendant, so I created an additional extension but the attendant box number is not an option in the forwarding... so my question is how do I get an incoming call from the pstn gateway to go to the attendant?
    Below is my 2651 config, I searched and there doesn't seem to be a lot of info on unsupported gateways for 3cx. A couple gottcha's first you have to set the pstn to not register and set your outbound rules to strip the 9. Hope the following config can help someone
    C2651#sh run
    Building configuration...
    Current configuration : 4358 bytes
    version 12.4
    service timestamps debug datetime msec
    service timestamps log datetime msec
    no service password-encryption
    hostname C2651
    boot-start-marker
    boot-end-marker
    no logging console
    enable secret 5 $1$frux$hI7F0TDJLVfgdNBlFqexk1
    enable password **********
    no aaa new-model
    clock timezone GMT-7 7
    no network-clock-participate slot 1
    no network-clock-participate wic 0
    ip cef
    ip domain name *******.***
    ip name-server ***.***.***.***
    vpdn enable
    voice service pots
    voice service voip
    allow-connections h323 to sip
    allow-connections sip to h323
    allow-connections sip to sip
    redirect ip2ip
    sip
    voice class codec 11
    codec preference 1 g711ulaw
    codec preference 2 g711alaw
    codec preference 3 g729r8 bytes 40
    codec preference 4 g723r63 bytes 96
    codec preference 5 g726r16 bytes 80
    voice class codec 1
    interface ATM0/0
    no ip address
    no ip mroute-cache
    atm restart timer 300
    no atm ilmi-keepalive
    dsl operating-mode auto
    pvc 0/32
    encapsulation aal5mux ppp dialer
    dialer pool-member 1
    interface FastEthernet0/0
    ip address ***.***.***.1 255.255.255.0
    ip nat inside
    ip tcp adjust-mss 1452
    speed auto
    full-duplex
    interface FastEthernet0/1
    no ip address
    shutdown
    duplex auto
    speed auto
    interface Dialer1
    mtu 1492
    ip address ***.***.***.118 255.255.255.248
    no ip redirects
    no ip proxy-arp
    ip nat outside
    encapsulation ppp
    dialer pool 1
    dialer-group 1
    no cdp enable
    ppp authentication chap callin
    ppp chap hostname *****@******.***
    ppp chap password 0 **********
    ppp pap sent-username *******@******.*** password 0 ***********
    ip forward-protocol nd
    ip route 0.0.0.0 0.0.0.0 Dialer1 permanent
    ip http server
    no ip http secure-server
    ip nat pool mpool ***.***.***.*** ***.***.***.*** netmask 255.255.255.248
    ip nat inside source list 1 pool mpool overload
    ip nat inside source static tcp ******************* extendable
    ip nat inside source static udp ******************* extendable
    access-list 1 permit ***.***.***.0 0.0.0.255
    snmp-server community public RO
    snmp-server community ********** RO
    snmp-server community host RO
    snmp-server community private RW
    snmp-server enable traps tty
    control-plane
    voice-port 1/0/0
    disconnect-ack
    input gain 4
    output attenuation 4
    no comfort-noise
    description to House Phones
    threshold noise -90
    station-id number 7851
    caller-id enable
    voice-port 1/0/1
    description to HS
    station-id number 7852
    caller-id enable
    voice-port 1/1/0
    output attenuation 0
    no comfort-noise
    connection plar opx 10003
    description 3CX
    station-id name pots incoming
    station-id number ***********
    voice-port 1/1/1
    dial-peer voice 10003 voip
    description 10003
    preference 1
    destination-pattern .T
    voice-class codec 1
    session protocol sipv2
    session target ipv4:***.***.***.17
    dtmf-relay rtp-nte
    no vad
    dial-peer voice 10000 pots
    preference 1
    port 1/1/0
    dial-peer voice 7851 pots
    destination-pattern 7851
    port 1/0/0
    dial-peer voice 7852 pots
    destination-pattern 7852
    port 1/0/1
    sip-ua
    authentication username 10003 password 0257540B5B55
    retry invite 3
    retry response 3
    retry bye 3
    retry cancel 3
    timers expires 300000
    sip-server ipv4:***.***.***.17:5060
    line con 0
    line aux 0
    line vty 0 4
    password **********
    login
    end
    C2651#
