first time install - "error lisence.html" ?
Discussion in '3CX Phone System - General' started by korenron, Jun 14, 2017.
  1. korenron
    Jun 14, 2017
    I have put the key that you sent me into the mail
    so what is this problem?
    this is the first time I install it on this computer (at all.......)
    what can I do?
  2. StefanW
    Jun 2, 2009
    1,234
    96
    Could you elaborate a bit more the issue and where you see this error?
  3. korenron
    Jun 14, 2017
    1.I have download and install 3CXPhoneSystem155.exe (next-next-next-install)
    2.run the tool from web browser.
    3. use the free key I got in the mail.
    4.next-next-next-finish .
    5. open the browser for setting , put all the information it want
    7. press "Finish"
    8. got error :
    License Activation Failed
    license_error.HttpsError
    Thanks ,
  4. Panayiotis_3CX
    Panayiotis_3CX Support Team
    Apr 26, 2017
    165
    7
    Hello @korenron,
    I have sent you a p.m. Please check your inbox.
    Thank you.
  5. zaur.q
    Jun 17, 2017
    i have this problem too
  6. YiannisH_3CX
    YiannisH_3CX Support Team
    May 10, 2016
    7,783
    564
    https.error is usually related to DNS issues. Please make sure that you can resolve activation.3cx.com from the PBX machine correctly.
    You can try setting your primary DNS server of the PBX machine to 8.8.8.8 and then flush your current DNS settings. Restart all services including the nginx service and try running the configuration tool again.
  7. zaur.q
    Jun 17, 2017
    license_error.HTTP/1.1 400 Bad Request Cache-Control: private Content-Length: 1647 Content-Type: text/html Server: Set-Cookie: ASP.NET_SessionId=yyss2ydrpdu0aw5zhlknp1nt; path=/; HttpOnly X-AspNet-Version: 4.0.30319 X-Frame-Options: SAMEORIGIN Access-Control-Allow-Headers: Origin, X-Requested-With, Content-Type, Accept Access-Control-Allow-Methods: POST,GET,PUT,DELETE Date: Mon, 19 Jun 2017 11:52:52 GMT
  8. zaur.q
    Jun 17, 2017
    i try a primary DNS 8.8.8.8 but it not help.
  9. DanielPL
    Sep 22, 2017
    I`ve already changed both DNS Servers (primary: 8.8.8.8 and secondary: 8.8.4.4) and it doesn`t work too. I restarted all services, restarted the server after, but the problem continues...
  10. GiannosC_3CX
    GiannosC_3CX Guest
    Hi DanielPL,
    Do you have any DPI (deep packet Inspection) enabled or are you using Proxy in front of the 3CX Phone system?
  11. StefanW
    Jun 2, 2009
    1,234
    96
    can you tell use your computer host name? does this contain any non UTF-8 cahrs?
  12. DanielPL
    Sep 22, 2017
    No DPI and No Proxy. SPI is enable in my router.
    I use host names for my MS AD server, by the way 3Cx Server is in domain. In 3Cx wizard i chose "Local IP" and the name's chars are all from UTF-8.
  13. GiannosC_3CX
    GiannosC_3CX Guest
    Hi DanielPL,
    Could you please disable this option? Please try to re-install the system after you disable the SPI option on the router and let us know.
  14. DanielPL
    Sep 22, 2017
    It didn't work.
    license_error.HTTP/1.1 400 Bad Request Cache-Control: private Content-Type: text/html Server: Set-Cookie: ASP.NET_SessionId=axqwamr0fsg4bv4xbg3hrgnh; path=/; HttpOnly X-AspNet-Version: 4.0.30319 X-Frame-Options: SAMEORIGIN Access-Control-Allow-Headers: Origin, X-Requested-With, Content-Type, Accept Access-Control-Allow-Methods: POST,GET,PUT,DELETE Date: Fri, 29 Sep 2017 18:45:54 GMT Content-Length: 1647
    Can i do something else?
