[FIXED] (403) Invalid Password Provided
Discussion in '3CX Phone System - General' started by wortel538, Nov 8, 2014.
  1. wortel538
    Nov 8, 2014
    Hello! im using Zoiper to connect to my 3xc... if i use lan ip (192.168.*.***) it just works fine, but if i try using my public ip it doesnt work, i forwarded the good ports... This error i will get:
    What to do?
    Greetings Wortel538,
    10,366
    227
    Re: (403) Invalid Password Provided
    I suspect that you have not enabled registrations, for that extension, from outside the LAN. It's a check-box option per extension.
  3. wortel538
    Nov 8, 2014
    Ah, thats it, thank you very much!
