Solved [FIXED] SBC not working properly on raspberrypi
Discussion in '3CX Phone System - General' started by jonathanv, Jun 28, 2017.
  1. jonathanv
    Jun 27, 2017
    11
    Hey,
    Since few days, I have a specific bug with my Raspberry Pi 3.
    I have 2 SBC with the same 3cxsbc.conf
    - raspberry pi 3, which is not working
    • Arm
    • Updated Raspian (debian 8)
    • Version 15.5.2607
    - kvm virtual machine, which is working fine
    • - amd64
    • - Updated debian 8
    • - Version 15.5.2607
    Here is the 3cxsbc.conf file :
    Code:
    [General]
    ReconnectInterval = 30 # seconds
    PrintStatsInterval = 30 # seconds
    FailoverInterval = 90 # seconds
    [Log]
    Type = file    # cout, cerr, file, syslog
    Level = VERBOSE    # NONE", "EMERG", "ALERT", "CRIT", "ERR", "WARNING", "NOTICE", "INFO", "DEBUG", "STACK", "CERR", "VERBOSE"
    File = "/var/log/3cxsbc.log"
    [Bridge/123456]
    ID = 123456
    Password = XXXXXXXX
    TunnelAddr =ip.ip.ip.ip
    TunnelPort = 5090
    #Optional
    Name = "3CX SBC"
    PbxSipIP =ip.ip.ip.ip
    PbxSipPort =5060
    SecurityMode = 0
    So now I'll be focus on RPI3.
    When I try to start application with :
    • /usr/sbin/3cxsbc -p /var/run/3cxsbc.pid /etc/3cxsbc.conf
    • sudo /etc/init.d/3cxsbc start
    • service 3cxsbc start
    It's the same, application doesn't start. sbc send packets to server ( tcpdump trace but server doesn't send response. I guess because sbc stop running)
    Here is the application response :
    Code:
      # /usr/sbin/3cxsbc -p /var/run/3cxsbc.pid /etc/3cxsbc.conf
    argument = /etc/3cxsbc.conf
    Application's full path-name = /usr/sbin/3cxsbc
    Full app pathname: /usr/sbin/3cxsbc
    Application path: /usr/sbin/
    ** Section: [General]
    ** Section: [Log]
    ** Section: [Bridge/123456]
    Finished
    log directory: File exists
    pure virtual method called
    terminate called without an active exception
    Aborted
    And the debug application logfile (stuck because of 10.000 chars limitaiton on forum ^^) : https://pastebin.com/2MsWeKfN
    Now, when I start application with
    • /usr/sbin/3cxsbc -p /var/run/3cxsbc.pid /etc/3cxsbc.conf &
    • strace /usr/sbin/3cxsbc -p /var/run/3cxsbc.pid /etc/3cxsbc.conf
    It works. So i must start application in background to work. That's very weird.
    Does someone already have / had this problem ?
    Do I have any way to increase logs ?
    I can provide tcpdump trace, strace ...
    Thanks and regards
    Jonathan
  2. saqqara16
    Jan 13, 2016
    43
    5
  3. jonathanv
    Jun 27, 2017
    11
    Thanks, but I also tried to uninstall, cleanup files and reinstall.
    This is not really an application problem, as It works fine when I launch it in background with &
    This is an app crash signal problem or someting similar :/
  4. jonathanv
    Jun 27, 2017
    11
    Actually it doesn't start anymore after a full new install :mad:
    Code:
    ** Section: [Log]
    Finished
    Aborted
  5. jonathanv
    Jun 27, 2017
    11
    I've just made a fresh install and everything is fine.
    Maybe there was a conflict because I was on debian repositories instead of raspian.
    [BUG CLOSED]
    Thx
