flash-hook on FXO
Discussion in '3CX Phone System - General' started by atik, Nov 7, 2011.
  1. atik
    Mar 29, 2010
    5
    Real strange problem...
    I need to connect on Special System (Bticino PBX) from 3CX,
    BUT! when open connection i need to send flash-hook signal and after number in DTMF (9911 or 9912 or 9913) to BTICINO
    Phone Cisco spa504g
    Gateway Smartnode 4112
    ..is possible to Emulate flash-hook via Phone ? (combination of key)
    ..or is possibile to force via Smartnode ?
    anyone have connect 3cx pbx with Bticino interphone system ?
    thanks for any solution
    Roby - atik.it
    10,587
    253
    While it might be possible to generate a flash, on a gateway (and if possible would be gateway specific using some sort of DTMF combination), connected to 3CX, I wouldn't hold out much hope.
    For the most part, gateways, connected via a PBX, are assumed to be used with a non-resiidential line , one not using PSTN features that require a hook-flash.
  3. atik
    Mar 29, 2010
    5
    Thanks leejor,
    i have search, and there is in sip information possibility to send Flash (char 16)
    Is possible in Outbound Call, set Flash (16) in prepend space ? with special char or other way
    or anyone with patton know how to emulate flash signal ?
    any other suggestion ?
    Table 1 summarizes the DTMF-related named events within the
    telephone-event payload format.
    Event encoding (decimal)
    _________________________
    0--9 0--9
    * 10
    # 11
    A--D 12--15
    Flash 16
  4. f.rossi
    Nov 8, 2011
    Hi, i have the same problem as you. I need to send the signal FLASH 7 to a bticino device to open a door from phones, and i don't mind if it is sent from the phone with a key combination or directly from the gateway through a dial plan, i just need the bticino to receive it somehow! I have yealink t26 and t28 phones and i could use a patton, linksys or grandstream gateway as needed... any ideas? thanks
